Fuel question
Fuel question
To make a long story short i have a 94 Lt1 Formula with all the basic bolt ons and most everything else. I have a completely stock fuel system. I want to bump my nitrous from 100 to 150 or more. I am looking into buying an inline fuel pump to help my fuel system out. What should I get. I was looking at the walbro inline pumps but they seem to flow alot for an inline pump. 255LPH to be exact. This seems a bit much for an inline pump. I dont even think my stock pump flows that much. Any advice would be appreciated. thanks
I don't have an inline pump but I can tell you my upgraded intank pump is a 255 lph. I am running a 175 shot with a 396 and no probs. I will also tell you I have a couple friends that run a 150 shot on stock fuel systems with no problems.
I'd recommend the Racetronix kit with the Walbro pump. Some people make inlines work fine but I see more problems with them than anything...plus its not going to pull more fuel from the tank...it can only push/help what the in-tank does. So its not going to supply a significantly great volume of fuel, which is what you really need with 150shot just as much as the pressure.
