Old 05-13-2016, 03:59 PM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:Browse all: Chevrolet Camaro or Pontiac Firebird Specifications & General Maintenance
Print Wikipost
What is the most common Engine Problems of Camaro Z28??
Old 10-21-2005, 02:02 PM
ZSU
ZSU's Avatar
Default What is the most common Engine Problems of Camaro Z28??
[IMG]What is da most common Engine Problems of 1996 Camaro Conv. Z28?? Or mechanical..
Attached Thumbnails What is the most common Engine Problems of Camaro Z28??-2_image_for_silan_540808.jpg
Old 10-21-2005, 03:56 PM
slowmofo's Avatar
waterpump went first on my Z. then the tranny, then the opti. Have not had any engine problems yet. Have seen a few lt-1 that were starved of oil at high speeds that looked like someone threw a gernade in the oil pan.
Old 10-21-2005, 04:10 PM
Chris 96 WS6's Avatar
Intake manifold oil leak, LOL
Old 10-24-2005, 01:05 PM
ZSU
ZSU's Avatar
hmm... Cool burnout..
Z28 wont make engine problems to meee too..
I am going to buy a 96-97, Z28, Transam, or Mustang gt in these weeks..
I am looking for a clear one with no crash
Old 10-24-2005, 05:04 PM
hashtagBMW
Speed Density's Avatar
OPTI then tranny here
Old 10-24-2005, 05:18 PM
flatlander757's Avatar
I've had the waterpump and alternator and starter go.
Stock opti is still ticking.
but I have 195,000 miles
Old 10-24-2005, 05:25 PM
Old 10-24-2005, 05:45 PM
kozak's Avatar
intake manifold oil leak, opti still stock.
Old 10-24-2005, 10:05 PM
Racafella13's Avatar
62,000 miles all that broke was the low coolant sensor
Old 10-24-2005, 10:39 PM
PGM95Z's Avatar
the oil pick up is prone to falling out, which leads to no oil, which leads to spun bearings, which leads to new engine...
Old 10-25-2005, 01:24 AM
1bottled93toenvy's Avatar
dipstick broke, oil pressure sensor broke, tranny, and exhaust leaks like a mother ******
Old 10-25-2005, 09:38 PM
State69champ's Avatar
Tranny and the fudging TPS
Old 10-25-2005, 09:58 PM
4u 2 nv's Avatar
intake gasket
coolant temp sensor
opti
breaking manifold bolts( for me at least)
pinion seal leak
sucking mustangs into the TB!!!
Old 10-27-2005, 10:19 AM
MY99TAWS6's Avatar
I had to fix intake manifold leak on my 97taws6. Its sold off now.
On my 96z have had to replace alternator,waterpump and passenger side window motor. I did replace things like tps and iac and other stuff but it was mostly for preventative maintenance and have done a lot of mods as you can see in the sig.
I plan on doing more maintenance and upgrade type stuff,have new racetronix fuel pump and harness to install in spring,new adjustable fuel reg think my stock one is acting up. Replacing opti maybe putting in delteq and will replace wires and plugs when install planned long tubes.
The lt1 seem pretty reliable.I am a bit worried about the auto trans,am installing zex wet kit also. I have bought window switch but expect to maybe have to buy upgraded trans in possibly near future. I think the intake leak is from the egr tube so close to the back of the intake.I recommend blocking egr if you don't have emissions testing.We don't so the egr will be coming off there.
Other than that the car seems good...have to replace my front rotors they are warped bad and my stock shocks seemed not so great at 60,000 miles but have installed new kyb agx.
I love my lt1 a lot,had a 96 ta and 97 ta ws6. I love my ls1 too.Both great engines.
Old 10-27-2005, 10:37 AM
blkchevyz's Avatar
besides crap i broke racing, i've only replaced an air pump and a starter.
i've had this car for almost 9 years now.
oh and stock opti
Old 10-27-2005, 10:44 AM
stevemilz's Avatar
Valve springs are junk on these motors
Power Steering pump
Intake leak (valve cover breather helps eliminate it)
Old 10-27-2005, 10:45 AM
stevemilz's Avatar
Power Steering pump
Opti
Quick Reply: What is the most common Engine Problems of Camaro Z28??
