383 Stroker
9-Second Club
Originally Posted by 96 LT-1
Can someone tell me what a "stroker kit" consists of? Is it a completely new block?
Thanks for any help.
Good luck, Ed
Bad Seller Warning!
well if i were getting a new block also... would you guys recomend me buying a stock motor for the (water pump alternator) things like that or shuld i buy them aftermarket or from other members on here?
Moderator
Yeah its usally the rotating assembly internals, you have to get your block machined, when you have it all together its a short block. You bring the machine shop just the block and nothing else, you can reuse your own or find one. I wouldnt reuse the water pump from another motor, alternator and the rest dont have any thing to do with it. When your looking for a core your just looking for the stock short block or a bare block, you dont need the complete motor with accesories you just need block to be bored and machined. Looking at kits make sure the kit is for a 87+ SBC, you need a crank with a 1 peae rear main seal.
What a short block looks like
Moderator
are there stronger blocks that sponsors or someone sells ? if so are they worth looking into? or would i be better off getting mine machined?
No one makes an after market block for the LT1s, your stock block is a two bolt main, you can upgrade to a 4 bolt out of a 92-96 Vette but a 2 bolt in most aplication will hold up just fine. The stock Lt1 block is iron and will take some abuse, Big Rick ran 8.08 at 172 on a LT1 block, that car was making 1238rwhp, through a glide and 9 inch, imagine the fly wheel HP. The LT1 blocks when built right are stout and can handle more than what prety much any one can throw at them.
