LT1 bogging in high RPMS
Old 01-03-2006, 08:09 PM
CK9887's Avatar
Default LT1 bogging in high RPMS
Ive got a 95 TA with just a CAI and a Flowmaster muffler... The car was bogging down real bad and missing down low and up top in the RPMs... I replaced the coil and the car runs smooth now except for up high in the rpms. At about 5k rpms it dies out and almost feels like it hits a rev limiter or something. Sometimes it doesnt do it but most the time it does.... Maybe needs new plugs and wires? Not sure when the last tune up on the car was done. Maybe fuel filter?
A sevice engine light will occasionally come on but will go back off if I turn off the car and crank it up again.
I also sprayed carb cleaner on the MAF and on the throtle bodys because there was some build up....
So What could it be?
Thanks
Old 01-03-2006, 08:10 PM
LS1TECH Sponsor
Ryne @ CMS's Avatar
i bet its the opti-spark
Old 01-03-2006, 08:35 PM
my94blackz's Avatar
If it boggs at high rpms, or dont pull like normal i would say mass air. If it studders at high rpms id say opti. If it sounds like its missing at idle and doesnt pull as hard id say plugs and wires.
Old 01-03-2006, 08:44 PM
CK9887's Avatar
its like it sputters and almost cuts out at high rpms... hmmmm
Old 01-04-2006, 01:50 AM
CK9887's Avatar
also... it seems when the car isnt fully warmed up it runs good. When I took the car out tonight, the first time i got on it, it ran smooth and then after that it started having trouble again.
Old 01-04-2006, 03:44 AM
Muncie4sp's Avatar
plugs/wires mine was doing the same thing up top.
Old 01-04-2006, 12:02 PM
CK9887's Avatar
if it was plugs and wires wouldnt it run shitty all the time.. not just at high rpms???
Old 01-04-2006, 12:25 PM
blkchevyz's Avatar
sounds like o2 sensors not the opti
Old 01-04-2006, 08:14 PM
CK9887's Avatar
hmmm... 02 sensors? I neverer thought about that
Old 01-04-2006, 10:13 PM
redhot lt-1's Avatar
Default high rpm miss fire
have a computer check at your local parts store some will do it for free. if not the o2 sensors do plugs and wires that may help but it sound like the opti
i had the same problem a few months ago it was the 5th one. i finally got a
after market opti form dynatech called a dynaspark for $615.00 but it was well worth it. they improved 10 different problems the factory unit had, and it was pretty easy to install. check it out at www dynotech-eng/dynaspark.htm good luck
Old 01-05-2006, 12:20 AM
CK9887's Avatar
damn...
Will a computer pick up any codes if theres no lights on? The service engine light comes on occasionaly but not all the time.
And if it was opti wouldnt it run shitty all the time? Cause it runs good... just once it hits high rpms it starts acting up
Thanks
Old 01-05-2006, 12:33 AM
Dragframe's Avatar
damn...
Thanks
no.. opti acts up at more or less random times
Old 01-05-2006, 12:47 AM
Renegade's Avatar
Yeah Opti's can do some funny crap, like drop random cylinders and fun things like that. Mine is out and I'm getting it replaced, it runs like crap all over the place, and now it's too the point it won't start. I would get it scanned and see if any codes pop up, if not, do plugs/wires, and try running some fuel injector cleaner through, or change the filter. Before you go ahead and look more into 02 Sensors and the Optispark. 02 Sensors should show something in the scan, is the car puffing any kind of smoke? It also wouldn't hurt to check the Cat... I doubt it's clogged but if it was the cat would be glowing red. It's kind of a crapshoot if no codes show up, and it's a bitch to take the car apart to see if the Opti is bad.
Old 01-05-2006, 12:57 AM
CK9887's Avatar
Ya I guess ill have autozone run a check on it tommorow and see if anything comes up... Could there be a chance that the coil i just bought is bad?I wouldnt mind replacing plugs and wires anyways if it wasnt such a pain in the *** to do cause i know it probably needs them anyways...
So heres the possibilities....
Opti
plugs/wires
Fuel Filter
02 Sensors
Old 01-05-2006, 08:08 AM
Renegade's Avatar
If it was your coil it should be throwing a code on the computer. There is a slight chance that the coil you bought is bad, but I doubt it. And it's kinda hard to mess up when installing a coil so I doubt that's the problem. And yes, you can pretty much narrow it down to those four things, but it could also be something else, it's hard telling... get the scan and let us know the results .
Old 01-05-2006, 03:10 PM
CK9887's Avatar
Well I went to autozone but they didnt pick up any codes... I bought a fuel filter and put it on and it didnt seem to help. I drove it and as sson as I hit 4500 rpms it just felt like it cut out... its not always at 4500rpms but usually around there or 5500rpms
Old 01-05-2006, 04:50 PM
cartmanchevy's Avatar
It sounds like the optispark in my opinion. Get an MSD cap, rotor, and wires. It sure beats the factory setup.
Old 01-05-2006, 08:43 PM
chrisn's Avatar
could your computer be picking up (false) knock and pulling timing? its a common problem with LT1's with headers or upgraded valvetrain but not as common in more or less stock applications. Just something else to think about.
Old 01-05-2006, 09:28 PM
CK9887's Avatar
hmmm.. well the car is mostly stock but I guess thats a possibility...
Old 01-05-2006, 09:29 PM
CK9887's Avatar
Do you have a link so I can check that out?
Thanks
Quick Reply: LT1 bogging in high RPMS
