Cutout Help
Old 03-28-2006, 12:07 PM
djkyle25's Avatar
Default Cutout Help
yo so i seen these cutouts for like 25 new ( non-electric) and im wandering if they are just as good as electric but ppl just like eletric cuz u dont have to get down under car and screw in some screws or wut? and cant ne muffler shop do it?
Old 03-28-2006, 12:09 PM
djkyle25's Avatar
o and does it really make it as loud as ppl say? lol
Old 03-28-2006, 12:10 PM
djkyle25's Avatar
o and does it really make it as loud as ppl say? and i would only need ONE right? cuz u do it before cat and it dont split till after cat conv. right?
Old 03-28-2006, 12:22 PM
94 z28 A4's Avatar
I have a 1994 z28 and i bought the non electric and got it put under the floor pan.
yes it really makes it loud like people say. I have a question too. What gears did you
have before the 3.73's and could you tell a difference in them? with 3.73' what
rpm's are you runnin at like 60 mph? thanks, Joe
Old 03-28-2006, 12:31 PM
djkyle25's Avatar
hmmm well i have a 6 speed, and the 373's were on when i bought it, and by floorplan wut do u mean, and from wut i heard, 373's do alright and make it FEEl like u have liek 40 more hp (feel keyword) and arent as good for power as 402's but as for rpm it all depends which gear im in u know
Old 03-28-2006, 12:32 PM
SS30ANV's Avatar
Installed an electric cutout in my 97 SS....after the cat and before muffler. Small button concealed in ashtray operates the cutout. The SS has a nice sound as it is, but when the cutout is open even sweeter. Had to put a small stainless extension pointing downward to keep the exhaust flow from heating up a rear floor panel. Made it a little more subdued than without the extension....but still sweet. Could probably get away with it open for the most part. A fun addition. Go with an electric.....so much easier to play with.
Here's a link to the one I got.....quality item and reasonable.
http://www.dmhperformance.com/photogallery.htm
Old 03-28-2006, 01:04 PM
djkyle25's Avatar
dont u do cutout BEFORe the cat for max flow and sound i thought that is wut everyone did, i had a hole cuased from vibration after cat and i got it fixed and not that much quiter
Old 03-28-2006, 01:46 PM
94 z28 A4's Avatar
Yes i got my cat. converter cut off. i had the cutout put underneath the rear floor pan is. i just leave my cutout open all the time. I am surprised i havent gotten pulled over yet either. It sounds really good especially with the cam i have.
Old 03-28-2006, 02:41 PM
hashtagBMW
Speed Density's Avatar
I Had my CO on the bend right after the cat, it sounded great.
Old 03-28-2006, 03:17 PM
djkyle25's Avatar
My car stock has 1 cat converter. And im PRETTY POSITIVE NO REAR O2 SENSOR.
The only O2's are the ones on the headers. So I will be getting a custom catted y-pipe made with 2 cats.
I also bought a cutout and am not sure where i should put it.
Before the cats, which would mean if cutout was open, i would be running headers only. (will that throw codes, and damage O2's?)
Or should i go with the cutout after the cats meaning headers and catted y, when the cutout is open?
Old 03-28-2006, 03:20 PM
slowmofo's Avatar
mines right after the y pipe with no cat
Old 03-28-2006, 09:31 PM
crAzy95Z28's Avatar
no need to go 2 cats. The 95 LT1's were made from the factory with 1 cat. Putting another car on there will cutback on your power. If you want just move the cat towards the rear end and put the cutout before the cat in the middle of the car.
My car has longtubed headers, no cats, and a cutout right before the rearend. Easy to get too when i put the cap on (which i never do) sounds too mean with my cam.
Old 03-29-2006, 12:04 PM
djkyle25's Avatar
ok well my cat is pretty much right after headers hit exhaust, so the cutout would be close to car,is that bad? and can someone explain knock?
Old 03-29-2006, 12:08 PM
-PEPE-'s Avatar
if your running a single C/O before the axle without electric it'd be a PIT to get to everytime. My old setup had dual 3" c/o's after the collectors (easy to reach w/no jack) that took less than 2 minutes with a 13mm wrench.
Old 03-29-2006, 02:42 PM
infinitebird's Avatar
Originally Posted by 94 z28 A4
what rpm's are you runnin at like 60 mph? thanks, Joe
www.f-body.org/gears
