AS&M 58mm Throttle Body, NE use one and not get WOT?
Old 03-29-2006, 04:59 PM
Steve40th's Avatar
Default AS&M 58mm Throttle Body, NE use one and not get WOT?
Just curious if anyone uses the AS&M throttle body and doesnt quite get 100% throttle opening. I have used the GM factory manual to adjust the throttle, but to no avail. It seems as if there isnt enough pull.
Look at this photo of a Holley where the guy fixed his WOT problem by putting the facotry linkage on his Holley, and look at the difference in length.
Old 03-29-2006, 05:25 PM
djkyle25's Avatar
YEA i have a 54mm TB and i have same problem i posted the same post like 2 days ago, and this guy tiold me to adjust it at pedal
Old 03-30-2006, 02:02 PM
Steve40th's Avatar
I think the linkage is wrong. A friend took a factory throttle linkage off of his Throtle Body and installed it on his Holley, and the problem was solved.
Look at the difference in length, hence more pull, Geometry thing.
Quick Reply: AS&M 58mm Throttle Body, NE use one and not get WOT?
