pedal throttle adjustment!
Old 03-31-2006, 06:09 PM
djkyle25's Avatar
Default pedal throttle adjustment!
hello i have a throttle body that is not WOT when i push the pedal all the way in, upon gettin under the steering wheel and pullin the pedal out i found that there was 1-1 1/2'' of extra cable that needed to be pulled at the pedal, there was a piece on the end of the wire that looked similar to
this (]= before the wire ends to stop it, i can not twist it down the wire or nething does ne one know how to move or adjust this, b/c its plenty tite up that TB i think
Old 03-31-2006, 07:47 PM
djkyle25's Avatar
ne one been here before?
Old 03-31-2006, 10:32 PM
crAzy95Z28's Avatar
try posting on www.camaroz28.com You get alot of replies prob faster than here.
Old 04-04-2006, 11:06 PM
Bud M's Avatar
You can just remove the pedal assmebly from the car and bend the rod so the pedal is further from the floor. The longer travel will do the trick.
Quick Reply: pedal throttle adjustment!
