Has anyone heard of this modification?
I heard from a friend of mine that there is some mod you can do to your LT1 that will pick you up a couple tenths in the 1/8 and a few MPH. (Around a 3-5 MPH increase) I'm not sure what it is yet, but I heard that you need to take off the throttle body in order to do it. What could this mod be?
Also, my friend told me having a CAI will make the modification more effective. I'm confused...
Anyone ever heard of it, or know what it could be?
It's the throttle body bypass, I really don't about the gains or the cai part but you basically take the coolant lines that route coolant through the tb and pull them from the tb and connect them so the hot coolant doesn't heat airflow through the tb do a search for it you'll find the details. And you don't have to pull the tb to do it.
It could be the throttle body bypass as was previously mentioned, and it could also be porting the intake manifold and installing a bigger bore throttle body. (Like a 58mm.) That would explain the "taking off the throttle body" part, since it's not actually necessary to remove the throttle body to perform the bypass mod.
You wont get a couple tenths or a couple mph from doing the TB bypass if thats what he's talking about. But IIRC WS6.com did a back to back dyno and picked up like 7-10whp with it all across the board.
He did try it and went from 78 MPH to 83 MPH in the 1/8...I still don't know what it is, but I know it's not the throttle body bypass. You wouldn't notice any kind of gain at the track with that mod.
Originally Posted by Shon Herron
Tell that buddy of yours to try it on his car and let you know the results.
(Answer: gnidneS elpoep no eht ten no dliw esoog sesahc si nuf.)
It's not a good friend of mine, so I can just find out. Why do you have to try and be an a$$hole? (Answer: Because I have nothing else better to do)
I'm just curious if anyone has heard of anything like this before, because it seems irrational.
Sorry "thesoundandthefury" for posting on a site that talks about this kind of thing. I guess I'll just go read other peoples threads and not help them now...
It's a thread that *I* started and as long as it's related to cars, I don't see why it's a stupid post.
2. Don't act all butt hurt when people start becoming suspicious of your claims because you can't keep your story straight.
Yeah, my butt does kind of hurt.
The boring intake thing was a good thought. Is that actually worth any gains? Will I need a tune or anything? Wouldn't boring the throttle body have a chance in causing my car to hit the rev limiter? (I have an A4)
