Comp Cams XFI 242/248
Old 04-14-2006, 12:12 AM
1sicss's Avatar
Default Comp Cams XFI 242/248
I was wondering if anyone has already had any experience with comp cams new XFI cams but more in particular with the XFI 242/248. If so what kind of numbers were you making with it and what are ya'lls mods along with the cam.
ANY FEEDBACK WOULD BE GREATLY APPRECIATED,
1SICSS THANKS
Old 04-14-2006, 12:40 AM
91Z28's Avatar
Good luck, I couldn't find any info on these cams. I finally found one guy running the 280XFI and bought it instead of the XR282HR on a 112 LSA. They've been out since late '04, and still no info.
Old 04-14-2006, 07:08 AM
aboatguy's Avatar
I just installed a 280 XFI, and like you I have not been able to find anything on the XFI series.
Mike
Old 04-14-2006, 12:32 PM
SStrokerAce's Avatar
FWIW, the RPM range that the specs of that cam are made for and the lobes don't go well together. It would be really hard to control the valves to get any benefit out of that.
Bret
Old 04-14-2006, 12:37 PM
91Z28's Avatar
Bret
Does the same go for the 280XFI? 230/236 .594/.588 (1.65) 113 LSA
Old 04-15-2006, 08:29 PM
91Z28's Avatar
I hope not, since that cam just arrived at my house on friday.
Old 04-17-2006, 10:20 AM
That is setup for a lower RPM range so the durations work better with the max speed you run... so your not as bad as the larger 242/248 cam.
Bret
Old 04-17-2006, 10:59 PM
fabgmc4me's Avatar
GMR Speed installed the 230/236 XFI cam into a 383ci with only a few mods, and stock heads. The car made 365rwhp and 395rwtq. The car idled perfectly after installing the cam (tuned of course).
Old 04-18-2006, 03:44 PM
91Z28's Avatar
Bret
I'm looking to make peak power 6000-6200, I guess time will tell if I fucked up or not.
Old 04-18-2006, 05:13 PM
DroppedM6Z's Avatar
I'm doing the 233/239 XFI and hope to be making 355rwhp cam only. Car made 304/343 Lt's and pullies with no tune. yeah it's a freak
Old 04-18-2006, 05:48 PM
91Z28's Avatar
233/239? Are you figuring the numbers after using 1.7rr?
Quick Reply: Comp Cams XFI 242/248
