car stumbling
Bad Seller Warning!
car stumbling
ok guys i have a 1996 M6 Formula when i launch it in first.... the car will start to go then the RPMs will drop then it will pick back up again after the delay.... let me kno your thoughts
You have to have it. You cant turn it off stock on a manual transmission car. The automatics have a little switch but to turn it off on a stick you have to buy a mod from somebody. Or track the right wires in the harness. Its a pain.
yo dude, i had same problem, does it feel like it drops a little and it doesnt have the power in the lower rpms??? if so thats wut mine did and i was missin some spark(a bad wire) and once higher rpms were reached the spark was able to jump, just a suggestion
