Anyone see any potential problems..
This is my situation. I have a 95 Z28. It is currently in storage setup on jack stands, battery out cause I got called over to IRAQ. It is stored in an insulated building, at probably 75 degrees in the summer. I put stable in the gas tank, and ran it to get it circulated through the fuel system. I think I blew the Head Gasket a couple of days prior to that. #7 Cylinder misfires and burns Antifreeze, and there is coolant mixed in with the oil. I took off the Headers, put rags in the exhaust ports, sprayed WD-40 under the Valve Covers, and inside that Cylinder. I started it right before I did all that to burn out the coolant from the #7 Cylinder. Is it a blown Head Gasket, or anything else, and should I worry about anything with that coolant all over in the engine.
