Throttle Body Mods 52mm TB and Foil
What is the deal with TB Foils
http://cgi.ebay.com/ebaymotors/LT1-L...63973343QQrdZ1
Worth while purchase?
ANd also 52 MM TBdoes it really give 15-20 hp to a stock motor?
http://cgi.ebay.com/ebaymotors/1993-...63133527QQrdZ1
Is that WAYY over priced? or is that reasonable.. ? Il be bidding if not
From what i have seen, the air foil really isn't worth the money. That money could be put into a new larger diameter throttle body that will not need an air foil.
Quote:
? 15-20 hp on a stock motor
? 50-100hp w/ cam and mild head work - i.e. valves & hand port
? 100hp+ on hot 383ci and larger motors
You will not get these kind of gains from just a throttle body. IMO there are more important mods to do such as intake, exhaust, gears, stall, etc. If you are looking for a throttle body, you can have yours ported out to a larger diameter, or you can spend some more for a brand name tb. You can get a holley 52 for a very reasonable price from some of the sponsers.
I have a Air Foil in my 97, and I could feel the difference. I mean I didn't even know it was there until a buddy and I took it all apart to look at my TB, and found it all cocked in my ducking. I was pissed. The one you are going to buy is better than mine, because of the set screw. I would go for it.
Location: king of prussia, pa (home) and williamsport, pa (school)
save up for a holley 52mm tb, thats my 2 cents
Originally Posted by emerica4601
i highly doubt u can feel a 2hp increase in your car.
