58mm Mono-Blade flows 1300 CFM. ANY GOOD?
58mm Mono-Blade flows 1300 CFM I was woundering if any has one one there car and notice the differents. if u know about them let me know cause i need a new TB. thanks of the output.
I think it depends on what u already have on ur car really, I have 58mm BBK, it flows 1000CFM, but i ported the intake inlets to the size that they fit.
I cant sa anything about resaults yet, cranking her up soon.
You can run it with heads and a good cam,good in size injectors, ported intake, and a good tune. There is no harm in CFM as long as you have the right combination to get it in good and out good.
you should enlarhe the holes in your intake for either one as they are smaller than 58mm.
withthe monoblade you should cut a large hole the size of the monoblade opening, withthe 58mm tb you just enlarge the bores to 58mm
brook
Originally Posted by Honda Hunter
Where can they be bought and how much?
what do u have?
I might trade u, I have BBK 58 and every one is tellin me its to big, I think its to late not, I just ported the intake inlet to fit the 58mm.
