Rocker Noise OR Exhaust leak?..
Old 05-15-2006, 08:11 PM
Lt1Son's Avatar
Default Rocker Noise OR Exhaust leak?..
Well i hear a tapping noise which sounds like its coming from the pass side vc..i thought it was a exhaust leak about 2 weeks ago...now its gotten louder at idle..but seems to go away at normal driving speed..inside the car when i gas it to pass in 6th i can hear what sounds like a leak...?im new to the lt1 so is it common for the rockers to get loose?...anby input woul be great thanks
Old 05-15-2006, 08:15 PM
streetwarrior96's Avatar
Most probably a leak. Do you get any poping sounds in your exhaust?
Old 05-15-2006, 08:23 PM
Lt1Son's Avatar
Default ..
Sorta..when i take my foot of the gas..but nothing at idle...most small blocks with exhaust leaks make it sound like it could be something a little more right?...Thanks for the help
Old 05-15-2006, 08:29 PM
StealthFormula's Avatar
I have the same exact problem. Ends up the air tube crap on my passenger side header has broken off from the header and I have no flipping clue what to do since I cant see how you could get in there to re-weld it.
Old 05-15-2006, 09:56 PM
the_merv's Avatar
Sounds like an Exhaust leak.
As far as your AIR problem, I would see if you can plug it, rather than weld it.
Quick Reply: Rocker Noise OR Exhaust leak?..
