Pacesetter header problems? Anyone experience this.
Old 05-16-2006, 05:34 PM
ZL1SS's Avatar
Default Pacesetter header problems? Anyone experience this.
Well, my car is getting finished up and I put PaceSetter mid length headers on and the damn whole where the check valves go are too big to fit the stockers! I can't believe this. Anyone experience this or is it just my bad luck. Any way to correct the problem without having to take them off and send them back? Maybe an adaptor or something?
Old 05-16-2006, 06:01 PM
sdm1234's Avatar
Are the check valves the A.I.R. tubes? If so, I had that problem and made my own gasket.
Old 05-17-2006, 09:52 AM
JL8Jeff's Avatar
The 94-95 AIR ports are different from the 96-97 I believe. Did you get the wrong headers? On my 96 SS I put the Pacesetter longtubes on and the AIR port was threaded all the way to the top. That caused a problem where the stock AIR fitting wouldn't seal because the fitting doesn't have threads all the way. So I just put some thick stainless washers in as spacers and haven't had any problems.
Old 05-17-2006, 10:05 AM
the_merv's Avatar
Just remove the AIR, and plug the holes in the Headers. You would be suprised how much better it runs.
Quick Reply: Pacesetter header problems? Anyone experience this.
