what size injectors?
Old 05-18-2006, 08:10 PM
slagger's Avatar
Default what size injectors?
Hi all,
I just got done rebuiling my motor
I just had it tuned and while i was getting on it on the freeway my injectors were in the red (datamaster) they were as high as 85%
They are the stock 24lb
should i go bigger 30lb?
thanks guys
355, 180cc AI heads & cam, port match intake,Mid headers,SLP intake,
Old 05-18-2006, 10:50 PM
buffman's Avatar
Originally Posted by slagger
Hi all,
thanks guys
Sounds like you do. I usually see people going to bigger injectors when they're hitting 85-90% DC @ WOT...
I'd highly recommend FORD SVO 30lbers
Old 05-19-2006, 01:01 AM
94greencamaro's Avatar
This might help you pick the proper sized injector
INJECTOR CALCULATOR
Old 05-20-2006, 04:08 AM
hvyss's Avatar
I am running a 355 with LE2 heads and a CC503. On 30lb SVO's I run at 60% cycle duty. I talked to LLoyd and asked if the 30 lb SVO's with be large enough for the LE2 cam and was told that the 30lb SVO's are like running a Dephi 36lb injector. When the SVO's and installed on a GM the lb rating is increased according to Lloyd. Hope this helps.
HVY SS
Quick Reply: what size injectors?
