Aftermarket ls1 springs on an lt1?
Old 05-23-2006, 11:05 PM
ReD95LT1's Avatar
Default Aftermarket ls1 springs on an lt1?
Hey guys like it says, i have a set of INTRAX 1" lowering springs off of an 98-02 trans am. Will they fit my 95 ta? Should be the same right?
thanks
Old 05-23-2006, 11:35 PM
BlackBirdWs6Zzz's Avatar
nope they are different. I know cuz I asked teh same question.
Old 05-23-2006, 11:45 PM
streetwarrior96's Avatar
?????? Isn't the suspension for 93-02 all the same?
Old 05-24-2006, 12:09 AM
ReD95LT1's Avatar
oh great they are?
I always thought it was the same?
Old 05-24-2006, 05:48 AM
leadfoot4's Avatar
Physicall, they should fit. However, the 98-02 springs should be designed for the lighter weight of the aluminun LS-1 engine, versus the iron blocked LT-1.
Old 05-24-2006, 06:59 AM
Shirley Temple Drinker
Sgt. Spuds's Avatar
yea it will sit lower, the LS1 prokit is like the perfect drop for a lt1
Old 05-24-2006, 07:06 AM
the_merv's Avatar
Depends on how low you want to go. The front will drop lower than the back.
Old 05-24-2006, 07:50 AM
ReD95LT1's Avatar
i dont want to go too low thats why i got the 1" because of the lt's
Old 05-24-2006, 11:21 AM
the_merv's Avatar
I have an Eibach Pro Kit for the LT1, it lowers about 1.5" all around. They advertise 1.3, but after it was all done, it was closer to 1.5".
Old 05-24-2006, 12:53 PM
OneFast97Z's Avatar
Yes, they will work
Old 05-24-2006, 01:28 PM
Honda Hunter's Avatar
Yes they will work. Find out the spring rate. That's what's important. Thatll tell you alot.
Old 05-24-2006, 06:45 PM
borninatransam's Avatar
look in summit and see if the eibach kits dont say 93-02.
Old 05-24-2006, 08:52 PM
NotACop97Z's Avatar
Agreed... If you look up the part numbers for the LS1 cars its the same as the V6 cars
Quick Reply: Aftermarket ls1 springs on an lt1?
