STOCK rear gear for 6/speed cars
Old 05-24-2006, 11:20 AM
SPACECITY's Avatar
Default STOCK rear gear for 6/speed cars
Anyone know what the stock rear gears are for M/6 cars.
I have a 95 T/A M/6.. thanks all
Old 05-24-2006, 11:23 AM
StealthFormula's Avatar
3.42's
the_merv's Avatar
3.42:1 Ratio, GM code GU6 in the Glove Box.
Old 05-24-2006, 11:31 AM
SPACECITY's Avatar
would changing to 3:55's make a difference??
I would still like some freeway manners.
I dont want 373 or 410's
Old 05-24-2006, 11:35 AM
blkchevyz's Avatar
not worth the money... that is if they even makes those for our rear end
your not going to loose much mpg going to 4.10s.
hell it makes 6th more usefull
Old 05-24-2006, 11:43 AM
emerica4601's Avatar
Location: king of prussia, pa (home) and williamsport, pa (school)
then again if you throw different gears in, your riskin blowin your stock 10 bolt.
Old 05-24-2006, 11:50 AM
blkchevyz's Avatar
what you dont think stock gears can blow? 3.42s do have a little more meat on them but if you got enough to blow 3.73 or 4.10 its only going to be time till you take out the 3.42
Old 05-24-2006, 01:00 PM
the_merv's Avatar
I blew apart the stock Differential with a basically stock motor, and I have an A4. Bigger tires is what does it really. I didn't change the gear ratio until later.
Old 05-24-2006, 02:54 PM
SPACECITY's Avatar
damn.
I have a 25.7 tall tire. 315/35's
so a taller tire wont be a problem
as i'm not running one.
I guess I'll stay with 342's
Quick Reply: STOCK rear gear for 6/speed cars
