Cam Qustion?
Cam Qustion?
Will the comp cams 07-306-8 xtreme energy cam fit in my stock lt1 motor? will there be any piston valve issues??? Here are the specs:
HYDRAULIC ROLLER-For use with LT1, with Hyd. Hyd. 1800 to 5800 07-306-8 290HR-12 290 307 230 244 .510 .540 112°
modified computer programming, intake
plenum, runners and 2200+ stall.
If this cam will fit okay what springs?, roller rockers should I go with also?
Moderator
Thats a CC306, do a search for it on CZ28.com. you can run it in a stock motor, that cam likes heads, wont run as good as it should on a stock headed car. Back in the day that was probably the only cam people used to hit 400rwhp was really opoular. No piston valve clearnace issues, lot of different springs, go with a 1.6 rocker. That cam sounds great but on a stock headed car theres better cams out there, even for a car with heads, newer cams out that make better power. That cam is from the late 90s, easy to get tunes for but theres new stuff out there.
Everyone on CZ28.com would always tell me it wouldn't run well on stock heads but it ran great. xxxsaintxxx was another guy with an M6 and CC306 running 115+ on stock heads. My s/n on there is 95_RipperZ
