I Need Fuel!!
I Need Fuel!!
ok i just put in the racetronix setup, the car keeps shutting off at idle, but is fine under WOT. I forgot to superglue the case closed, does anybody know if this will cause the car to run out of fuel like that?
also, the pump is wired up completely independant of the PCM. Does the PCM do anything when it no longer sees the fuel pump??
thanks
thanks
