Canton Oil pan leak?
Old 05-29-2006, 07:37 PM
BarneyMobile's Avatar
Default Canton Oil pan leak?
Got a small little issue with my Canton LT1 oil pan. It leaks oil out of the little plug just above the oil drain plug. I tighten it and still leaks, so I put some tephlon thread sealant on it and it seemed to have slowed the leak but the leak is still there. Any suggestion?
Old 05-29-2006, 09:16 PM
jonlil77's Avatar
Default Drainplug
Had the exact same problem,so i used an oil pan drain plug that came with a gasket instead.Bought it at advance auto,but i don't remember the size though
Old 05-29-2006, 09:41 PM
harvickgm's Avatar
are you talking about the oil level sensor???
Old 05-29-2006, 09:47 PM
dhdenney's Avatar
Had the same problem with a Canton pan. I fought it forever. I bought a Fumoto drain valve and use a ton of teflon tape, problem solved. I shouldn't ever have to remove it ever again.
Old 05-29-2006, 09:49 PM
harvickgm's Avatar
for my leaks on the oil pan like for my oil level sensor and drain plug, i use to use liquid teflon made by GM... good stuff, but i use grey RTV on them and dont have any problems...
Old 05-29-2006, 10:36 PM
NoMoreLS1's Avatar
Smile
Canton Oil pan=leaks
Old 05-29-2006, 10:56 PM
Ls1Bait's Avatar
mine dosent leak
Old 05-29-2006, 11:32 PM
streetwarrior96's Avatar
no leaks here!
Old 05-30-2006, 09:23 AM
NoMoreLS1's Avatar
Smile
The Canton oil pans that I have seen must have been made on Mondays.
Old 05-30-2006, 10:14 AM
dhdenney's Avatar
I think mine was one of them.
Old 05-30-2006, 11:08 AM
Fire67's Avatar
I just coated that plug with PTFE paste sealant and solved the leak. Oh yeah, tighten the **** outta it too.
Other than that, not a single leak
Quick Reply: Canton Oil pan leak?
