Need help finding a good tuner in TX?
Old 06-06-2006, 11:59 AM
396LT1's Avatar
Default Need help finding a good tuner in TX?
I from Austin,TX and need help on tuning my 93 camaro. It's a speed density set up. Currently running a PCMforless mailorder tune. I took it to the dyno to see how accurate it was but the A/F was to lean (14.2) at WOT. I added more fuel, but now it runs to rich. What I have is:
396 Stroker;CR 11.4;heads AFR 210;Comp Cam custom grind cam 230/236; ;625/627 lift on lobe 112, pacesetter long tubes with full exhaust. MSD 6AL, LT4 intake;
If anyone knows of somebody that can tune speed density car please let me knkow.
In advance Thanks,
Old 06-06-2006, 01:57 PM
tyrsmkr's Avatar
If you havn't, check out http://www.afbforums.com
Thats the local fbody club. They can help you find what you need.
Old 06-06-2006, 03:11 PM
396LT1's Avatar
thanks
Old 06-06-2006, 03:13 PM
tyrsmkr's Avatar
np man, sounds like you got one sweet ride. Ill have to check it out sometime!
Quick Reply: Need help finding a good tuner in TX?
