replacing rear main seal
Old 06-07-2006, 10:16 PM
NOTAV6's Avatar
Default replacing rear main seal
is there anything else i should replace while im doing it.... oil pan gasket, etc.... thanks for the input
Old 06-07-2006, 10:49 PM
harvickgm's Avatar
the oil pan gasket can be a PITA.. i did my oil pump a while back, with no air tools on the ground with a cherry picker... and it was a pain, but can be done. if its not leaking dramatically then i wouldnt worry about it.. i would recommend getting the tool to install the rear main seal..i have seen people try to tap them in and not get them right and pour oil everywhere... its never fun pulling the tranny back out...
Old 06-07-2006, 10:55 PM
NOTAV6's Avatar
what tool???? lol
Old 06-08-2006, 12:29 AM
harvickgm's Avatar
damn im not sure of the name of it.. i can check for you but basically you insert the seal in the tool the tool has 2 screws that you hand crank down into the bolt holes for the flywheel, once tight you crank down the big handle which pushes in the seal evenly all the way around.. i will look for one and post it up for ya...
Old 06-08-2006, 01:34 AM
NOTAV6's Avatar
thanks i appreciate it
Old 06-08-2006, 05:11 AM
leadfoot4's Avatar
The current issue of GM High tech Performance magazine has some pictures of a small block build-up. One of the pictures shows the tool, and how it fits in place. The text with that photo emphasizes the need to properly install the seal.
Old 06-08-2006, 12:02 PM
NOTAV6's Avatar
damn it ive been looking for the magazine lately and cant find it at any of the usual places to buy it i think a lot of places recently stopped carrying it
Old 06-08-2006, 04:20 PM
Captainofiron's Avatar
you have to buy that tool from snap on, it works for all one piece rear seal GM V8s
Old 06-08-2006, 04:56 PM
harvickgm's Avatar
and v6's.... i think it goes for any 90 deg chevy motor
Old 06-08-2006, 05:15 PM
dhdenney's Avatar
Check Autozone. They will loan one to you (if they have it) for free. (Just have to put a security deposit on it.)
Quick Reply: replacing rear main seal
