Driveshaft?
Old 06-13-2006, 09:57 AM
BarneyMobile's Avatar
Default Driveshaft?
I need to kno whats a good driveshaft upgrade. My stock driveshaft vibrates and has one bad u-joint. I'd like to get another one for my new motor setup. I keep hearing about going to the LS1 aluminum driveshaft. Will an LS1 driveshaft hold up to 400+rwhp. If not than what are some good companies to look at. I dont want to spend a ton and I want something that will minimize vibration. Thanks in advance!
Old 06-13-2006, 10:50 AM
streetwarrior96's Avatar
sphon extreme duty or the top gun with 1350 u-joint
Also change the differential yolk out to a 1350. Randy's ring and pinion has the upgraded yolk for a GM 7.5 $75.00. Thats the route I took. I twisted and broke the LS1 drive shaft, and broke the yolk with my 383.
Old 06-13-2006, 04:27 PM
Rare96WS6's Avatar
I run the LS1 drive shaft on my TA, so it hold up to 400rwtq quite well.
Old 06-13-2006, 04:31 PM
dhdenney's Avatar
With slicks you probably won't have much luck with an aluminum one. I twisted my Lingenfelter 3.5" aluminum. Streetwarrior96 made a couple good suggestions for steel shafts. I went with a Denny's Nitrous Ready but it's kinda $$.
Old 06-14-2006, 09:04 AM
lt197formula's Avatar
i second the dennys nitrous ready driveshaft, i just ordered mine. 3 inch steel virtually unbreakable sounds good to me.
Old 06-14-2006, 05:31 PM
chevy94c's Avatar
Denny's ds is a good piece.
Quick Reply: Driveshaft?
