Error code 16-Low resolution error.
Ok. I pretty much got the jist of what this code means. If I am using the delteq system, would this still be the opti crapping out, because you still use the otpi for the cam pin sensor right? Am I getting warm, or am I way off. Anyone with delteq chime in.
Thank god. Them delteqs is expensive. I have alot of crankcase pressure due to new engine and high boost, which I plan on taking care of that, but I drove it and the dipstick popped out and sprayed oil, and I think it may have gotten on the opti connector. I just hope it's just the opti cable, because doesn't that cable go from the opti to the wiring harness?
If the opti was bad though, or the connection, that means the opti isn't working, which means the ignition isn't going to work either right? The opti isn't doing it's job to tell the coils when to fire.
And, what could happen to the engine if you drove the car with that problem?
Yes, my car is still running. I just don't want to drive it if this problem is going to do any damage to it.
Ok, so since that error is on the pcm it has shut my fuel system off? I guess that's why it sounded like I was running really low octane fuel b/c it wasn't getting any? And also, since I AM using the delteq, same principals apply, as far as the opti still being good(even though everything is not through the opti) because the car is still running? I did hook up the datamaster to it, and after it was in closed loop, with that error, I was still getting fuel.
How do I get the error out of the pcm? Will it go off by itself?
