How the heck do I do the TB bypass?
Ok, I read somewhere that on 97's, the TB bypass is a little different, can someone please elaborate on this? I have the hose connector, but there seems to be a piece of metal tubing I need to disconnect, I just need some help!
I think the 97s are the same as my 95. On mine there was a metal tube running from the back of the motor connected to the thottle body with a hose. Remove this hose and take the other hose that runs from the thrittle body to the radiator and connect it to the metal tube you removed the other hose from. Should be no parts required to do this mod.
