torque converter
torque converter
can someone tell me how to find out if my torque converter went out... my car wont go anywhere how can I find out if its causing all my problems???????
It is probably your hydraulic pump. Did you jack the car up by the tranny at all or have a cracked bellhousing?
do a stall test. if the rpms are where they are supposed to be, should not be it. not that familiar with autos but i think the pump is mechanically connected to the tc (the clunk you get when a tc sinks before you install the tranny). not sure how you could tell if it was just the pump other than line pressure maybe. good luck
