Custom grind cam or no?
Old 07-02-2006, 03:53 PM
ShadyPhi's Avatar
Default Custom grind cam or no?
Ok fellas... bear with me here...........
Whats the benefit of getting a custom grind cam rather than just your
normal cam out there... like a hot cam, gm847, cc306 ...etc...
Whats the pros / cons of a custom grind?
Old 07-02-2006, 03:57 PM
harvickgm's Avatar
the best for custom grind cams is to get the heads done by the same people or someone they recommend... that makes for the best H/C combo...
Advanced Inductions
Joe O and Eric
Lloyd Elliot
all of those are good ones....
Old 07-02-2006, 05:23 PM
Hark_Z's Avatar
Look up Bret Bauer, no one better. And yes get a custom grind cam, more ppl should.
Old 07-02-2006, 05:31 PM
vanilla89's Avatar
i agree,get a custom cam from bret
Old 07-02-2006, 06:01 PM
James Montigny's Avatar
Bret does a great job and he's a nice guy to deal with.
Old 07-02-2006, 09:36 PM
Smokey TA's Avatar
where do i look up bret
Old 07-02-2006, 09:49 PM
seawolf06's Avatar
With a custom cam, they'll be able to design a cam to maximize your entire setup. For instance, I wanted a cam that would be mean on the street and awesome at the track, but still drivable and wouldn't be too hard on the valvetrain. I also wanted to stick with stock injectors. The CC305 was a little smaller than I wanted, and the 306 was a little too big for my stock heads, but I wanted room to grow when I get headwork. I picked up a 226/231 from cam motion with a lot more lift than the 305 had. I could have gone bigger, but got this one at a great deal. You can go with an off the shelf cam and you'll be very happy, but a custom cam will maximize your setup and give you more what you're looking for. Call up Futral Motorsports and they'll hook you up. Just my .02.
Old 07-03-2006, 12:21 PM
ShadyPhi's Avatar
Great explanation, thank you!
