Help What Is A Good Cam And Heads Combo
there is a story i will make it short but my car caught on fire but most of the motor is still good i pulled the motor and tranny out and i am puttin it in a 1st gen rx7. since the computer is fried i am gonna carb. it. but i need to know what is a good combo for a set of heads and cam. should i go with a lt4 cam and heads or somthing like AFR HEADS and a comp cam. please help
go to this link... do alittle research before just throwing up post... its all been answered.. but this link will answer your questions...
https://ls1tech.com/forums/lt1-lt4-modifications/535106-custom-grind-cam-no.html
Well if you going to carb it i say your in the wrong section. You may want to look here.
https://ls1tech.com/forums/small-block-big-block-chevy-specific-92/
I am very happy with ported LT1 castings and a cam from www.advancedinduction.com but frankly if you are going to carb it you are throwing away a big part of what makes an LT1 work so well so just sell it and put in a gen 1 motor.
