Hot cam but no heads
Old 07-03-2006, 10:05 AM
Alpha-Q's Avatar
Default Hot cam but no heads
How much am i going to gain if i go with LT4 hot cam kit with stock heads?
Old 07-03-2006, 11:00 AM
laxmad16's Avatar
i was also wondering about this, i also heard that there is a head/cam package for somewhere around $1600 that will give you about 400 hp is this true?
Old 07-03-2006, 11:06 AM
blkchevyz's Avatar
hot cam works pretty good with stock heads. i put down 344 hp with it.
Old 07-03-2006, 11:21 AM
besz28's Avatar
yes with the hotcam kit which comes with 1.6 roller rockers 325-345rwhp is about where you'll be,if you have cai,headers,exhaust.....good luck
Old 07-03-2006, 12:14 PM
Alpha-Q's Avatar
You might wanna check this out then.
www.eportworks.com
Old 07-03-2006, 01:54 PM
the_merv's Avatar
I am happy with the Hotcam, it works. I haven't had a chance to Dyno it, I have to get my LT's on it before I do.
Old 07-03-2006, 02:42 PM
Alpha-Q's Avatar
i know you will feel the difference after you install LT. But, could you feel the difference with just the hot cam?
Old 07-03-2006, 02:43 PM
ringram's Avatar
I loved mine on my '93 supposed to be around 430fwhp. I could break traction in 3rd gear (M6) at 90 mph in the dry. Yeehaa.
Old 07-03-2006, 02:46 PM
the_merv's Avatar
Yea, I got the full kit and 3.73's at the same time, so there was a definate difference..lol
Old 07-03-2006, 03:19 PM
mike1500's Avatar
Lloyd Elliot! LE2 package or the LE3 But I think its the LE2... www.eportworks.com
Old 07-03-2006, 04:02 PM
laxmad16's Avatar
yeah i just checked the le's out what do u guys think is the best for an almost dd(have a truck) will i see a huge difference between the le1/le2/le3
Old 07-03-2006, 04:08 PM
HIGH SPEED LT1's Avatar
Is that to the wheels or at the crank?
Old 07-03-2006, 07:01 PM
Alpha-Q's Avatar
RWHP Dude...344 at the crank is peanuts.
Old 07-03-2006, 07:52 PM
zlover129's Avatar
344 on a hot cam? thats a bit high, you didn't have any other mods done other than the usual headers and exhaust and CAI?
Old 07-04-2006, 01:29 AM
camar0corey's Avatar
Those le packages are nice looking, seems for $300 more than buying assembled trick flow heads, you get 400+rwhp out of the le2 package. Wish I knew about this before I rebuilt my top end.
Old 07-04-2006, 09:54 PM
Compstall's Avatar
I've dyno'd mine cam only (no tuning) and gained 24 peak hp but over 30 gained past 5k, and was still making power at the factory redline. Torque stays about the same until after 5k also and gains over 30 above 5k. I just got the pcm tuned and will be dynoing again very soon.
One thing I noticed comparing dyno sheets is that the hotcam makes identical power to the stock cam until 5k. This is on stock tuning though so we'll check the differences once I get it dyno'd again w/ tuning.
As you can see the Hotcam doesn't help much for street driving on stock tuning and the rev limiter will cut you short at ~5700 so it's good to raise the rpm limit so you can actually see some good gains out of it at high rpm.
Old 07-04-2006, 10:32 PM
LT1Charlie's Avatar
Default Hot Cam
Hot cam kit, stock heads, Mac shortie headers, SLP loudmouth,
bmr suspension put me the High 12s in a 95 z28 with 90,000 miles on it.
Old 07-05-2006, 01:45 PM
blkchevyz's Avatar
just normal bolt on. didnt even have an electric water pump.
Old 07-05-2006, 07:55 PM
Rare96WS6's Avatar
344 is good for his mods, but achievable. I have a buddy with a 6 speed, the only other main mod being ported heads and he puts down close to 40 more. Mine is an auto and I put down 380. It all depends on what supporting mods you have, and if you got a decent block from the factory.
Quick Reply: Hot cam but no heads
