emissions coming up
Old 07-05-2006, 11:49 AM
imnotplutonium's Avatar
Default emissions coming up
should I just buy a nice hi-flow cat or pay someone to pass it? if I get the cat then it will pass there after but paying someone will be a yearly thing.
also with my mods what high flow cat will be garanteed to pass. I still have my egr and air and all of that. just no cat with my LT's and ORY.
Old 07-05-2006, 03:18 PM
bump...
Old 07-05-2006, 04:38 PM
bone324's Avatar
Maybe a cheap catted y-pipe that you could easily swap out whenever you need to test? I'm curious to know what others are doing besides paying off a mechanic to break the law.
Old 07-05-2006, 04:51 PM
lastcall190's Avatar
One cat AFTER the y-pipe isn't going to do much, in fact I still doubt you'll pass. Might as well either get a dual catted Y that you can swap in or out (as stated above), or just pay someone. Good luck man.
-J
Old 07-05-2006, 07:19 PM
bone324's Avatar
Didn't the '93-'95 F-bodies only have one cat in the y-pipe? I thought only the '96-'97s had the dual cats.
Old 07-05-2006, 07:45 PM
infinitebird's Avatar
that's correct. only 96+ (and the 95s made in cali) had two
Old 07-05-2006, 09:13 PM
FlamingChicken's Avatar
go with the catted y. finding someone that is willing to pass you is extremely difficult. i speak from experience. i have read that even people with strong h/c combos pass emissions by swapping out injectors and leaning everything out. also i dont think you can put a cat at the end of the y unless yours is a lot shorter than mine (kooks). the cat will hit the driveshaft.
Old 07-05-2006, 10:05 PM
well if i was going to make it permanent i would just cut the y and get the cat welded on.
Old 07-05-2006, 11:53 PM
bone324's Avatar
Well, I purposely added cats to my car for emmissions. I have shorty headers with highflows in the y-pipe in pretty much the same location as stock. I'm considering getting LT's and just swapping in the shorties and catted y for testing which is a big pain in the ***.
Old 07-06-2006, 12:12 AM
Kizzle's Avatar
Think cutting the ORY and adding a Cat would be cheaper then just swapping pipes to a catted y ?
Old 07-06-2006, 12:17 AM
Chris95Z's Avatar
a single catted y should be adequate. I have a single cat, granted it's stock and huge, but it has been good enough to pass the sniffer here in Ca all the while being at the end of the y. I'd imagine Texas has a more forgiving requirement.
Old 07-06-2006, 01:15 AM
95z28camaro's Avatar
What I did to my car was I took it to a local muffler shop and got them to flange the cat. so it only has to be hooked up once a year for inspection and then I keep it straight thru pipe. It's not to much louder at idle but when you get on the gas then dang. My car picked about a tenth and it only cost $100.
Old 07-06-2006, 01:27 AM
big dave's Avatar
I got the magnaflow cat with a flange welded on for quick removal. Unfortunately, with my combo, I still failed...barely. Leaning it out only made matters worse, perhaps I was a little too lean.
Old 07-06-2006, 12:44 PM
yea i wanted to do the flanged cat and straight pipe but the shops I went to seemed like they didnt understand or couldnt do what I was asking. would a local muffler shop do it? i mean is it legal for them to do it? and here in college station they dont have a sniffer test but im not sure if they look for the cat or not.
but in the case I have to go to houston and get sniffer'ed a single cat on the y would work?
Old 07-06-2006, 01:18 PM
bone324's Avatar
I'm positive that any local exhaust shop that has any f'ing clue what they're doing could put some flanges on a cat and a straight pipe. It's legal as long as you explain that it's for "offroad" use only. If they don't have a sniffer, it's unlikely that they have a visual inspection.
