LT4 Hot Cam Shift points..... Help!
Hey all
I'm getting ready to install the LT4 hot cam kit, and I'm getting a tune immediately afterwords. I'm curious, where should I be shifting (what RPM) after the install...
I need to know this in order to raise the limit on where the PCM cuts off the fuel...
Thanks!
Thanks!
I have mine set a little past peak power which is at 6200. Shift points are at 6400. Anywhere from 6200-6400 seems to be good for the Hot cam, from the other dyno and track times I've seen for this cam. Most cars make peak power from 5800-6200
with this cam, so those figures make sence.
9-Second Club
Originally Posted by ShadyPhi
Hey all
Thanks!
Thanks!
Good luck, Ed
9-Second Club
Originally Posted by burnzilla
6500 is alot of RPM's for the LT1, even with the hotcam kit.
I wouldn't push over 6200 rpms, but thats just me.
Many don't really race, just pretty much want to hear it lope when idling through the Sonic. I shift those guys at 6200.
