Car wont roll over??? HELP!!!!!!!!!
Old 07-05-2006, 09:16 PM
xxxtreme36's Avatar
Default Car wont turn over??? UPDATE!!!!!!
after i got done changing my inline fuel pump and turning the key back and forth to listen for the fuel pump the starter just stopped going, so now when i turn the key i hear a click in the ignition and the starter does nothing. What gives?? was my ignition switch wore out? i check all fuses and relays and any wiring i touched and all fine. Somone please help
Old 07-05-2006, 09:42 PM
teamguru69's Avatar
are you sure that your battery isnt dead? check your termainals i had the same problem in my old car..
Ps..i think that you mean your car wont turn over..
Old 07-05-2006, 10:03 PM
xxxtreme36's Avatar
yeah the battery is brand new and i thanks i did mean turn over . My dash lights up, and my fuel pump will prime, but the starter wont do anything and i know thats new also
Old 07-05-2006, 10:55 PM
aggiez28's Avatar
your trying to roll over your car??????????
Old 07-06-2006, 01:37 PM
TurboZ28's Avatar
Put in a new battery. Just grab one out of another car to see if it'll crank it.
Old 07-06-2006, 01:42 PM
-PEPE-'s Avatar
check your wires on your starter, especially the ignition wire, 8mm box end put a little snug on it, also check the big honkin wires that tie in as well. Sounds like a bad starter if not a loose wire.
Old 07-06-2006, 03:45 PM
xxxtreme36's Avatar
even if it was the battery wouldnt it atleast make the starter click or something? doesnt make sense since i was turning it over time and time again checking the fuel system, what about the VATS
Old 07-06-2006, 04:16 PM
xxxtreme36's Avatar
ok well i tried the new battery thing and that wasnt it, i looked at the cluster and im not getting a SES light or a security light when the key is forward. I tried banging on the starter to see if itd even attempt and nothing. Any givers on the ignition switch? I need to get this fixed by sat, thanks for your help
Old 07-06-2006, 04:22 PM
Charging TA's Avatar
Heres a guide for the ignition switch: http://shbox.com/ignsw/ign_switch_repl.html
Old 07-06-2006, 07:24 PM
xxxtreme36's Avatar
so do you guys think its the ignition switch? i got the column out, i guess i hope thats it, if not what next????????
Old 07-06-2006, 07:36 PM
mike1500's Avatar
Maybe the lil black square on the key isnt transmitting?
Old 07-06-2006, 08:10 PM
xxxtreme36's Avatar
yeah thanks mike, FUNNY!!!!!!! eh he
Old 07-07-2006, 04:53 PM
xxxtreme36's Avatar
ok well i changed my ignition and it still does the same thing, i need some help guys??????? all the bells and whistles work, no ses light or security light
Old 07-07-2006, 04:59 PM
jmill96Z's Avatar
You still have VATS?
Old 07-07-2006, 05:57 PM
LTSpeed's Avatar
If all the bells and whistles work, it's not the ignition switch. Do you hear the fuel pump whine (priming) for a few seconds when you first turn the switch to ON (not START)?
Old 07-07-2006, 05:59 PM
xxxtreme36's Avatar
yes i think i still have VATS, just got the car 2 months ago and i didnt take it off, everything works, fuel pump primes then shuts off after a few secs. If it is the vats how do i get passed that? theres no security light on either
Old 07-07-2006, 07:58 PM
jmill96Z's Avatar
That's the vats. Same thing happened to me one day. Car was running fine,parked, and an hour later same symptoms. I even tried to push start mine. It would run for like 1 second and would shutoff.
Old 07-07-2006, 08:00 PM
jmill96Z's Avatar
You can either tune it out, or pay big bucks for a new cylinder and matching key set. The best way to do it is to go to shoebox's site and ohm out your key. This way you can pay 30 bucks and find out wether the problem is the key or cylinder
Old 07-08-2006, 01:36 AM
xxxtreme36's Avatar
so what if it is the cylinder? than big bucks either way? Ive seen the shbox diagram but i dont quite understand it, can someone elaborate and fill me in on how to do this
Old 07-08-2006, 01:47 AM
harvickgm's Avatar
the VATS system kills the power to the fuel pump...so if its priming its not the VATS... make sure you have good connections at the starter and test the power at the starter. when you did the inline pump where did you wire it into?? is it an auto or manual???
Quick Reply: Car wont roll over??? HELP!!!!!!!!!
