Why can't LT1's use the crank gear to advance or retard a cam?
Old 07-07-2006, 09:31 PM
matt94z's Avatar
Default Why can't LT1's use the crank gear to advance or retard a cam?
Like the title cays. How does it throw opti timing off? Any info apreciated. I did buy off set cam bushings just in case, but I want all the info I can get.
Old 07-07-2006, 09:48 PM
GIZMO's Avatar
Because, with an opti-spark, if you move the cam you move the ignition timing. If you have DFI or a crank trigger you can make up for it.
Old 07-08-2006, 12:45 AM
DeltaT's Avatar
Why would you want to move the cam? +4 or -4 degrees is a VERY subtle difference, and not really worth the hassle. If you're a racer I can see doing it to tune to the track conditions, but with the LT1/4 it's too much of a hassle to make it worth it.
Jim
Old 07-08-2006, 04:33 AM
matt94z's Avatar
The cam is on a 105 icl and needs to be on a 108icl.
Old 07-08-2006, 02:23 PM
slick1851's Avatar
Because its not a honda
Old 07-09-2006, 02:43 AM
DeltaT's Avatar
You will never notice 3 degrees.
Jim
