alum. vette heads vs stock z28 heads
Old 07-12-2006, 02:37 PM
95 Camaro Z28's Avatar
Default alum. vette heads vs stock z28 heads
other than the obvious weight difference, what kinda flow difference are there between the two heads?? im looking for something to go w/ the lt4 hotcam, but dont need anything too radical just something that flows a little better...
would it be worth my time to get a set of Alum. vette heads of a 4bolt lt1 and swap them onto my motor??
Old 07-12-2006, 03:15 PM
JAB
JAB's Avatar
LT1 F-bodies had aluminum heads as well. Only the B-bodies had the iron heads so i don't think Vette heads would do anything for you, unless maybe it was an LT4 vette.
Old 07-12-2006, 03:18 PM
they dont flow any better, being from a vette?
Old 07-12-2006, 03:22 PM
JAB
JAB's Avatar
If it's just the LT1 head then no, I wouldn't think so. They should be identical but someone will correct me if i'm wrong.
Old 07-12-2006, 03:24 PM
streetrod93's Avatar
JAB...you're correct....there is NO difference between the vette lt1 and the camaro lt1...except for the 4 bolt mains....and the price tag.
most vette owners don't know that....they think they got something special
Old 07-12-2006, 04:00 PM
alright, i guess ill just continue to look around for some stockers with a p&p or something, tho i dont wanna spend more than like 500
Old 07-12-2006, 05:21 PM
Armyman2445's Avatar
Im taking off my stock heads. Im going with a set of iron heads P&P'ed to the max with larger valves. Wanted Iron due to boosted motor. I was planning on selling old heads around $100 if you're interested. Im swapping them out around first of august.
Old 07-12-2006, 05:30 PM
no thanks man, i dont need stockers, my stock ones are fine. just lookin to see if any1 perhaps has some stockers that have a mild p&p that they are getting rid of.
Old 07-12-2006, 10:38 PM
why not pull yours off and have them ported?
Old 07-12-2006, 10:46 PM
slagger's Avatar
LOL don't tell the vette owners that.
Old 07-13-2006, 12:37 AM
i cant have any down time, pulling them off and sending them to le or even having it done locally will take a while, id rather just pick up a set. i dont need to, i can always use stock heads w/ the cam, just figured if some1 wanted to get rid of one for under 500 id take it.
Old 07-13-2006, 12:48 AM
blind527's Avatar
Why don't you just buy the stock set for $100.00, send that in to LE and get LE1 or LE2 or whatever you want, have those installed, and sell the stock ones on your car now?
Old 07-13-2006, 08:16 AM
generally i don't have to tell them....most of the time they pull into the parking lot BEHIND me after they get the bright idea to play around....usuallly ends up in an severe beating for the vette....not many of them can hang with an 11 second street tire car...
chalk another one up for the f-body's against the plastic fantastics.
Old 07-13-2006, 08:31 AM
Honda Hunter's Avatar
Wasnt it a different cam, not heads that gave them the 300hp rating vs the 26x rated camaro same year?
Old 07-13-2006, 10:20 AM
GIZMO's Avatar
No. It was the exhaust. Otherwise the only difference is the mains.
Old 07-13-2006, 10:40 AM
Not according to this thread
http://forums.corvetteforum.com/showthread.php?t=956100
Old 07-13-2006, 11:56 AM
METALBEAST's Avatar
The only cam difference in the Vettes and the F-bodies was the 92 Cam. It was different than the cams in the 93-97.
Old 07-13-2006, 12:10 PM
GIZMO's Avatar
I just skimmed over the thread, but I can't find where it says that Corvette LT1's get a different cam from F-Bodies. All of the listings that I have seen show the same part number. I have never heard of a difference, but that doesn't mean that their isn't one. Maybe you can come up with specs. or part numbers?
Old 07-13-2006, 10:15 PM
the cam change he's talking abou happend for the vette between 92/93....93 is the first year for the f-body lt1, so we are also equiped with the "new" cam that he was talking about....
so in short, once again...vette owners just think the got something special....but in the reallity of it....they got the exact same parts
Old 07-13-2006, 10:34 PM
Then where did the Vette get the extra 25-35 extra HP? Couldnt be strictly exhaust change. I wish I could see dynos between the two stock for stock year for year.
