lt1 IN late second gen camaro
Old 07-13-2006, 01:13 PM
LZeppelin513's Avatar
Default lt1 IN late second gen camaro
I am looking to swap a lt1 into a late second generation camaro and was curios as to what I would need and what problems i would run into, thanks.
Old 07-13-2006, 01:35 PM
Honda Hunter's Avatar
It depends. It's not easy but it's not hard if you have all the parts, time, and patience when new things pop up while doing the swap. First of all do you know what tranny youre going to use? If you use a older tranny itll be easier to hook up the speedo. Also I recomend you go with a corvette assembly bracket, alt, AC, and powersteering for space reasons. Will you go carb or FI? If carb itll be easier but a lil more expensive because youll need to buy the setup. Kmember should be fine. If you go FI itll be alot tougher. Painless makes wiring harness for people doing these typ of swaps to make it easier.
Old 07-13-2006, 01:38 PM
burnzilla's Avatar
_____________
It can be done. This car had 400 Hp.
(Yeah Yeah, I know its a First Gen.)
Old 07-13-2006, 01:49 PM
That's hawt but I'm sure that shop is expensive. Where the heck is the alt?
Old 07-13-2006, 03:45 PM
I was gonna get an engine and tranny from a 93ish comaro LT1 and swap that in and keep it tpi
Quick Reply: lt1 IN late second gen camaro
