1.6 Crane Rocker Clearance
Old 07-13-2006, 08:59 PM
edlt1's Avatar
Default 1.6 Crane Rocker Clearance
Did anyone have a problem with the valve covers with roller rockers?
if so what did you do to fix the problem.
I do not want to relocate the alternator.
Old 07-13-2006, 09:23 PM
zlightning's Avatar
The problem isn't with the cranes it's with the comp pro mags, or I should say I have never read about a clearence problem with the cranes.
Old 07-13-2006, 11:04 PM
edlt1's Avatar
whats the problem with the comps?
Old 07-13-2006, 11:12 PM
edlt1's Avatar
Also are the 1.6 Roller rockers Worth it on a Stock Lt1 motor?
Gives a higher lift right
Will I even notice a difference, or is it more or a wear n tear mod?
Old 07-14-2006, 02:52 AM
camar0corey's Avatar
I'm running the 1.6 promagnums. I'm happy with them, but well the car was only running 100% for 2 days before I had to leave, so yeah....
I don't know if its true with the other companies roller rockers, but with the comps you have to grind down the support looking deals. you don't have to cut them out, just grind them down flat. I also took a little metal off of the top insides, made the ridges a little flatter, but something tells me you don't have to flatten those also, I just did it cause I was having fun with my new rotary tool.
Old 07-14-2006, 04:48 AM
mike2244's Avatar
i had to cut out the baffles out of my valve covers.
Old 07-14-2006, 05:13 AM
z28hustle's Avatar
i am also having this problem .. but when we even set the stock valve covers next to the motor it just looks like they cant ever clear .. i dunno wtf! You are saying that all you have to do is just cut out the baffles though huh? simple as that??
Old 07-14-2006, 07:18 AM
Chris 96 WS6's Avatar
Its probably worth it on a stock motor....to go with longtubes as a poor-man's cam change, but you will need to change out the valvesprings as the extra lift will bind the stock springs.
Old 07-14-2006, 08:13 AM
edlt1's Avatar
How much of a power gain could I expect?
Probably nothing over 5hp right?
Old 07-14-2006, 11:20 AM
buffman's Avatar
The only rockers that need valve cover clearancing are the PRO Mags because they are a wide body RR. Cranes and the GMPP rockers are narrow body RRs and most of the time do NOT have clearance issues. Only clearancing that needs done is usually bending the "L" shaped support brackets straight, and crushing the oil baffle on passenger side.
