Anyone running LE2 heads with a cc306
Old 07-15-2006, 04:41 PM
nhra_crazy's Avatar
Default Anyone running LE2 heads with a cc306
Just checking to see if anyones running this and how it works together..
Old 07-15-2006, 10:10 PM
roadtrip120's Avatar
Ya a friend of mine has it, search for a post of mine awhile back on the dyno numbers, over on camaroz28.com
Personaly i dont like it , it made 400rwhp lean as crap, it had no torque down low compared to my le2 setup . Just buy the cam from bret and you will be better off .
Old 07-15-2006, 11:47 PM
blackz93's Avatar
T/A LT1 or something similar over on cz28 has it and traps 120.
Old 07-15-2006, 11:57 PM
Gun5's Avatar
i was gonna go LE2 with 306 but mechanic said go 305 so i did.. got torque all the way through
Old 07-16-2006, 11:01 AM
Chopstix's Avatar
if I had known you were changing cams I would have sold you my old one cheap....
Old 07-16-2006, 11:22 AM
streetrod93's Avatar
the mechanic is an idiot when it comes to matching cam's to heads. the cc305 is way to small for those heads....it's a great cam for stock untouched casting, and it's old technology.
unless for some reason you're worried about emissions, i would go with AT LEAST the cc306....but as mentioned earlier, i would just have brett grind the cam to match the heads.
Old 07-16-2006, 03:04 PM
daniel6718's Avatar
305 might pass emissions i thought it required a pretty good tune...a 306 can i thought on a great dyno tune...but i agree i run a 306 on stock heads and the orque is there with a stall...the power is up there with the cam...i woulda gon 306 with heads prolly an gm847...**** you know what while lloyd was doing my heads i would have got a custom cam from him....hmmm good idea...an extra 50 bux...he coulda put springs to match with everything checked all by one person....
Old 07-16-2006, 03:18 PM
Wicked94Z's Avatar
a guy or two on cz28 hit 400+rwhp or something with the CC306 and LE1 heads. I've got a CC306 on stock heads right now, throwing on a set of ported stock valve units from Jason Short and we'll see what it'll do in 2 weeks. I think there's a thread or two of guys running the LE2 heads with CC306s but i dunno where it was.
Old 07-16-2006, 04:10 PM
Gun5's Avatar
ill probably eventually change cams i dunno i will see, but i should be making around 400 with my setup i hope
Old 07-16-2006, 04:32 PM
96blkform's Avatar
I was running that setup last year on my 350 shortblock before doing my stroker. I was running LE2 heads, cc306, 1.6 NSA rockers, 58mm tb, stock Water pump, Pacesetter LT's and borla catback, 93K on the motor. It made 383rwhp and 365rwtq running very rich (just on a mail order tune). I would have loved to see what it would have done on a dyno tune, it should have easily made 400rwhp. The car felt quick and had decent street manners, the combo really came to life at 3500+ rpm through 6500.
Old 07-17-2006, 01:48 PM
nhra_crazy's Avatar
Awsome thanks everyone
Old 07-17-2006, 02:45 PM
T/ALT1's Avatar
There are probably better cams out there than the 306 but it really works well on n2o. I have run 121mph N/A and since I found some valvetrain problems I was having it should do better than that. Plan on running a converter with 3,500+rpms. Later Clint
Old 07-17-2006, 03:21 PM
scrmnws6's Avatar
I made 400rwhp with the LE2 heads and the LE2 cam.
The numbers would've been higher if I installed the cam correctly by degreeing it. I made a thread about it on CZ28.com, check it out.
Quick Reply: Anyone running LE2 heads with a cc306
