Guages acting weird??????????
hmmm. well i guess i can start there.
Also my car is losing rpms when im at a stop or going from neutral to another gear. What could be that cause? No SES light comes on unless i let it go then the light goes away after i take off
both are symptoms of low charging voltage. Could be low battery voltage, low alt charge, high resistance of a loose or corroded battery connection, or an altogether unrelated issue. But that is the best place to start.
well then im gonna start with the battery and go from there. I know its a new redtop optima but ill take it and have checked and then go down the line. Thanks alot you guys, anymore sugg let em rip!!!
