Single Plain w/ IntakeElbows.com set-up
Who on here is running this set-up?
Im thinking about ditching my 90mmTb and 100*elbow and going with this set-up.
How much more does it clear? It looks to be atleast 1" or so.
Anyone know?
How much more streetable is it than going with the 90mmTB?
any other info would be appreciative.
Anyone know?
I've seen this new setup and consdired using an AZ&M mono blade, last TB I'd ever use on it would be a POS Holley, learned my lesson after 2 new Holley's, they're junk. I figured the 90mm would be a much higher flowing setup than a 58, even a mono, wouldn't this be stepping back from going with a bigger TB???
Originally Posted by Tony Shepherd
The monoblade will flow 1300 cfm. The 90mm will flow 1150 cfm. The 58mm flows around 1000 cfm. You will never need more than 1000 cfm unless you are reving to the moon and pushing 1000 hp+.
I just wanted to take a second and say thank you for planting a seed of rationality in this thread early. Now maybe it won't turn into a "I won't belive anyone that says I don't need an overly large TB" uphill battle.
Originally Posted by asudecat
I think im going to go ahead and save myself the trouble and go with that elbow and an AS&M 58mm TB.
So If anyone wants my elbow and 90mm TB let me know.
Jason
Jason
Originally Posted by Fbody4Ever
Brettinator what's your issue with the Holley 58's?
