Radiator & Low Coolant light PROBLEM!!
Old 07-18-2006, 04:02 PM
My25thTransAm's Avatar
Default Radiator & Low Coolant light PROBLEM!!
Ok, I need some help with this one guys....
I drive about 10-15 minutes to work almost everyday in this west texas heat, and when the temp gets a little over a 1/4 on the thermo it throws a Low Coolant light. Now, once it did that I popped the hood and got it on a ramp and noticed that my coolant thingy (where you check it) is full, as well as the top of the radiator itself. What the hell is going on??? I caught a leak that seemed to be going into the dash of my car (heater?) and everything seems to be fine as far as leakage now that i fixed it. What am I doing wrong? Why is it giving me this? Could something be stopped up inside of a hose somewhere restricting coolant flow? It doesn't get too hot on me, (< 1/2way on gauge) I'm stumped. -b
Old 07-18-2006, 04:12 PM
streetwarrior96's Avatar
low coolant sensor on the radiator might be bad
Old 07-18-2006, 04:15 PM
wicked_95z's Avatar
Those low coolant sensors are junk. even if you buy a new one it could go by in a week. I have seen it. Just unplug it and go about your business
Old 07-18-2006, 04:17 PM
Thats exactly what happend to me, thats exactly what I did. **** $60.00 everytime it goes out
97BlackLT1TA's Avatar
Mine did this also. It was a bad coolent level sensor in mine. Wasnt on all the time, but i checked it many times and it was always right where it was supposed to be. If it really bothers you replace the sensor and be done with it, if not its not going to hurt anything.
Old 07-18-2006, 06:06 PM
Azthrei's Avatar
I had that same problem in my bird. I didn't get a new sensor, just got a new radiator because it had holes in the old one. I didn't want to spend the money to get a new sensor, and anytime the radiator gets low, I know it, because it's usually spewing out a hose that came off or blew a hole in it. I would just unplug it, and check it each night after you fill up on gas, or in the morning to let it cool off. Those sensors suck ***.
Old 07-18-2006, 08:29 PM
So it could be a sensor? I guess it makes sense since I fixed the one leak I had. Where is this sensor anyway? And also, does it really cost around 300 dollars to have a tune? I called a place out here in Lubbock and they said it's around 350 for an LS1, and the only other place he knew of that tuned LT1s was in Oklahoma! Dubya Tee Eff?
Old 07-18-2006, 08:34 PM
San Antonio
Old 07-19-2006, 01:48 PM
PunishedU's Avatar
I guaruntee the low coolant light is just a bad sensor. Happened to me after i was having some cooling problems and it kept scaring the crap out of me that I was low again. Mine would also come on after the car warmed a little. Got a new one and no problems so far.
Old 07-19-2006, 02:13 PM
coldkillinTA's Avatar
where is this sensor located on the radiator? mine comes on randomly and i know its not low cause it never gets hot and its always full.
Old 07-19-2006, 08:54 PM
wicked_95z's Avatar
Its that little box right under the radiator cap on the fan side of the radiator
Quick Reply: Radiator & Low Coolant light PROBLEM!!
