Any trick on changing spark plug wires LT1
Old 07-18-2006, 05:56 PM
z28fan's Avatar
Default Any trick on changing spark plug wires LT1
Any tips on changing the miserable Passenger side plug wires - I managed to curse my way through the 4 on the drivers side. However the Passenger side is impossible - underneath - from the top or any angle.
1997 LT1 Trans am -
Is there any special tips, tricks or ideas to do this?
Old 07-18-2006, 06:00 PM
LTSpeed's Avatar
Yeah, do the A.I.R. delete mod first! You wouldn't believe the difference.
Old 07-18-2006, 06:02 PM
z28fan's Avatar
Never heard of it, could someone please explain I'll do it if it saves me the 4 hours of wrench throwing and cursing
Old 07-18-2006, 06:07 PM
Azthrei's Avatar
Get LT headers, clears those spark plug wire and spark plug replacement problems right up.
Old 07-18-2006, 06:10 PM
z28fan's Avatar
That would be great but- For now Have to stick with stock exhaust.
Old 07-18-2006, 06:36 PM
Black99TransAm's Avatar
take the alternator off... that helps alot. i can do my wires total in about 45 minutes...
Old 07-18-2006, 06:38 PM
z28fan's Avatar
Ok I'll try that - How much room does moving the alternator give? And is it hard to take off and reinstall?
Old 07-18-2006, 06:42 PM
97BlackLT1TA's Avatar
No it is not hard to take off. I dont remember exactly but its either 3 or 4 bolts, 1 wire held on with a nut, and one with a clip, then the belt. It frees up alot of room for the front 2 plugs and all the wires. You just have to make sure you have lots of different extentions and swivels and some patients. After a few changes you will be a pro, and wonder why it took you so long to do it the first time.
Old 07-18-2006, 08:13 PM
z28fan's Avatar
Just out in the garage looking at the altenator, seems like that may help some. Your talking about removing them from top correct?
Now for the back one (number 8) is it best to remove the starter?
Old 07-19-2006, 07:06 PM
carzman5678's Avatar
I didnt take off the starter. One trick is a few beers and some time lol
Old 07-19-2006, 07:47 PM
z28fan's Avatar
Well I got them changed- taking off the alternator gave it enough room to get my hands in there somewhat. Still took a lot of swearing and crawling on top and bottom of the car.
Seems one of the biggest problems I had was that the stock wire looms did not want to let go of the wires very easily. Next time (if there is one) should be easier.
Thanks for the advice everyone
Old 07-19-2006, 07:51 PM
Vendetta's Avatar
having a heavy bag in your garage works wonders as a stress reliever when working on cars.
Old 07-20-2006, 11:51 AM
lt197formula's Avatar
the use of small ambidextrous asian children comes in quite handy
a few hours, like vendetta said a punching bag, and some beers
Old 07-20-2006, 12:13 PM
imnotplutonium's Avatar
Yea one of my least favorite things to do in the world, plugs and wires on the lt1. Running them the stock way with manifolds.... errrrrrr. Now with LT's and over the valve cover kit makes it a lot easier.
Make sure to check all of your wires so they dont touch the manifold!!!!!! I went through way too many wires because I thought they were far enough. and those things are not cheap.
Old 07-20-2006, 01:38 PM
coldkillinTA's Avatar
does anyone know where to get the Taylor over the valve cover kit? or any over the valve cover kit? thanks
Old 07-20-2006, 02:15 PM
hashtagBMW
Speed Density's Avatar
Ill sell you my Taylor wires and OTVC kit if you want it.
PM me.
Tony.
Old 07-20-2006, 02:24 PM
http://www.thunderracing.com/catalog...vid=4&pcid=104
2nd from the bottom, I have this kit and it works great.
Old 07-20-2006, 03:31 PM
yea got mine from thunder. I would recommend having them pre-cut for your motor. cause doing it yourself sucks ***** and takes a while, that or I just suck lol
Old 07-21-2006, 06:13 AM
leadfoot4's Avatar
Although it sounds crazy, get the car up on stands, drop the "Y" pipe, alternator, and power steering pump, just like the factory shop manual says, and 7 of the plug wires are easily accessed. #2 cyl. is still a little tight, but doable. I've had my car 10 years, and did the wires at 5 years, and just did them a couple of months ago.
First time, I was stubborn, and didn't pull the p/s pump. It was frustrating. This last time, I pulled the p/s pump, which was a litle tricky, but once I did, the wire replacement went a lot quicker.
Old 07-21-2006, 10:16 AM
firebirdformulaTA's Avatar
i say just get LT headers makes **** alot easier.
Quick Reply: Any trick on changing spark plug wires LT1
