lt1 engine bay pics
lt1 engine bay pics
well after some time the stroker sits pretty good in the sonoma, still gotta do so clean up and install some FRC's whichshould make it look way better. Im also gonna clearance my valve cover so the alternator fits with a stock bracket then just need some sticky tires and pray for traction
thanks its a Lloyd Elliot top end(LE2) with matching cam(LE3) on a Victory Racing engines forged 383. I should be getting it dyno tuned sometime hopefully in August
its a 95 single cab the swap was not really that bad the only real pain in the *** was the exhaust system(i would go with long tubes if i had to do it all over again but at the time I didn't want to drop a grand plus on some) it was very tight, although i did clearance the frame on both sides for clearance becuase my y pipe was so close and notched the frame for the deeper oil pan. I had to cut and notch the front radiator support to get my fan not to hit the EWP which still only clears by a 1/2 inch but still clears
