cam brand/type/specs
Old 07-20-2006, 05:49 PM
undercoverz-28's Avatar
Default cam brand/type/specs
i'm looking to put a cam in my LT1 but not sure what kind. i've been told a Comp Cam 306 or something but i forget every time someone tells me. i'm trying to get into the low 12's eventually, currently i have 285 WHP and 320 ft/lbs, this is just my next step, the one after this being, building the heads and some roller rockers. i was told a good head and cam combo can add 80 - 100 HP. so if anyone has a good website, brand or type and where it can be found or what specs i should look for when looking at cams it would be much appreciated. thanks.
Old 07-20-2006, 06:11 PM
MrBill97396's Avatar
cc306 or gm847 are great agressive cams
thunderracing.com
Old 07-20-2006, 09:14 PM
thanks
Old 07-20-2006, 11:16 PM
Armyman2445's Avatar
custom grind. the way to go
Old 07-21-2006, 02:44 AM
94EvilZ28's Avatar
Do heads and cam at the same time. Alot easier to do it all at once...Do a search on Lloyd Elliot...and you can get your numbers from there...
Old 07-21-2006, 08:46 AM
lt197formula's Avatar
I run the cc306 it is a fun cam
Old 07-22-2006, 12:37 PM
skatinjay27's Avatar
are you running your 306 with the stock head(no port work)
Old 07-22-2006, 01:57 PM
Burning Rubber's Avatar
i also have the 306 cam in my LT1
