turbo cam ?s
turbo cam ?s
what do you guys think is a good turbo cam im looking at lpe 74219 which is a 219/219 @ .050 .560/.560 lift with a 1.6 rocker. the engine is stock except for 1.6 rockers, full length headers, off road ypipe 3 inch exh. 4.10 gears upper/lower ca's. i install a t67 with and 84 hot side turbo remote mounted built by myself just looking for cam while the motor is out
find a cam with the powerband in the rpm range that you want to run your engine. to keep it tame for daily driving run somewhere around 220-230 on a 114-116 lsa to keep valve overlap to a minimum.
Turbos thrive on exhaust pressure, and with that turbo being set so far back on the exhaust tract it helps to keep the pressure high with something like shorties or exhaust manifolds and a muffler before the turbo to get it spooled up fast. I would suggest a boost-driven cutout as well for maximum power. Also, swap those 4.10s for a 3.73 or so, it's better to have less of a gear with turbo setups.
