here is my problem
Old 07-25-2006, 01:35 AM
GTP PWR's Avatar
Default here is my problem
Before my lifter colapsed 5 months ago....my oil pressure gauge had been very shacky. I would have a max of 70psi when I first started it up, then when it warmed up I would have 40psi...it never went below 30.
I was told it is a bad sending unit...here is why. when I gas it ...oil pressure is fine, but when I brake hard..the oil pressure drops dramaticly. when I do a really hard stop...say at the end of the strip, my check gauge light comes on and my oil pressure is at 0.
only while braking hard. for a while it was really shaky then it went to 0 for about a week. I drove it to and from work(no clanging,knocking or anything. everything had oil. then my lifter went and now I have my new setup.
I took it out, had fun and then I noticed it acting up again....while braking. I was told it might be the oil pickup, but sounds to me like the pressure sensor. the car has always done this. anyone care to shed a little light on the subject?
Old 07-25-2006, 01:38 AM
buffman's Avatar
wouldnt hurt to pull the drain plug and stick a light up there and make sure the pickup didnt fall off the pump. IIRC that's the typical problem associated with a pickup falling off.
Old 07-25-2006, 07:39 AM
harvickgm's Avatar
mine does the same....its because there are no trap doors to hold the oil in the pan... so when you brake really hard all the oil flows to the front of the engine and the pressure drops... thats why at the end of the track i was just killing the motor and then slowing down... that way i didnt hurt anything... a nice new canton oil pan will fix that right up... lol...
Old 07-25-2006, 09:40 AM
NOTAV6's Avatar
same thing happened to me the sending unit on the back of the block/intake was fubared, replaced fine ever since
Old 07-27-2006, 10:23 PM
lt1_2buku's Avatar
I have the same problem... but. I think it is my oil pressure sending unit. When i put the motor back in i forgot to put it back on the block now i am having a hard time finding a socket that will give me enough room to tighten it down. Does anyone know if it is a special socket or have any other ideas?
Old 07-27-2006, 10:35 PM
harvickgm's Avatar
yep... there is an oil pressure sending unit socket out there.. but i got mine on with a wrench... and no leaks here...
Old 07-27-2006, 11:11 PM
buffman's Avatar
yeah AC Delco has a special socket. Bought it at this tool wholesale place for liek $3.00 Lifetime Gaurantee and AC DELCO brand. :O
Nonetheless you should be able to get a wrench on it, or a deep wheel socket of that size.
Old 07-27-2006, 11:23 PM
GTP PWR's Avatar
so its either my pick up, oil pan, or my sending unit?
how much are sending units? I'll rule one out at a time.
Old 07-27-2006, 11:26 PM
harvickgm's Avatar
like i said mine drops under heavy braking due to nothing in the pan keeping the oil in the bottom of the pan.... so the oil flows forward... leaving the sump empty or almost... i want to get a canton oil pan just for that reason.. but they are quite pricey... around 280 that i just dont feel like spending...
Old 07-28-2006, 04:19 AM
Cammd95Z's Avatar
Jacob!!! That Car Is Cursed!!!
Old 07-28-2006, 05:21 PM
lt1_2buku's Avatar
sending unit would probably be the cheapest and easiest if you had the right socket. I think i got mine for 15 dollars or something like that at autozone. Maybe cheaper. BTW thanks for advise on tightening it fellas
Old 07-30-2006, 01:08 AM
GTP PWR's Avatar
I bought one from advanced, the guys up here at autozone are morons.
