My Pacesetter y pipe is touching one of the brake lines
The Pacesetter y-pipe I installed is touching what I believe is a brake line. It is the one with the coil wrapped around it, right behind the drivers side header and brace.
I'm going to assume this is bad. Has anyone successfully fixed this without redoing the exhaust?
Originally Posted by MattZ28
So bend the brake line.
What kind of wrap? I was thinking some high temp heater hose. I just want to make sure the brake fluid doesn't get hot or the fuel if that what it is.
I might try some fiberglass header wrap that I saw on ebay and wrap the pipe that's touching the lines. Do you think that'd work? And maybe get a piece of high temp silicone hose to put around the line.
I might try bending it too. I didn't want to though because I was afraid of crimping the line.
