Stock 1994 Z28 A4 bin.
Old 07-31-2006, 04:11 AM
Honda Hunter's Avatar
Default Stock 1994 Z28 A4 bin.
Can someone send me a stock tune for a 94 Z28 A4 so I can return the camaro to normal today. My email is souljaslim4life@aol.com Thanks
Old 07-31-2006, 04:24 AM
LT1BRN's Avatar
ok, this might be retarded but I know nothing about tuning or PCMs, if you can copy mine from the PCM i will be more than glad to help, at least I'm 10 minutes away.
Edit**
the site you posted yesterday has it if I'm not mistaken, and I believe they fixed the bug after I emailed them.
Old 07-31-2006, 04:50 AM
Edit**
The problem with downloading from those sites is it's hard to know what's virgin for sure. I was hoping someone had it on thier harddrive and could account for it. I have to go to work in 2 hours and I need to send the tune to my friend to download it before then.
Old 07-31-2006, 04:56 AM
http://www.bfranker.badz28.com/LT1Edit/LT1files.htm
Links still broke
Old 07-31-2006, 05:59 AM
titter's Avatar
they all worked for me :O the stock 94 z28 file on that site isnt stock either ... it is the same as the 94bin with the hpp tune ... however the 95 stock z28 is the same as a 94. the only changes in 95 computer wise was that traction control actually worked in some models of the 95 z28 if it had traction controled on the car. be sure to rename the files from .zip to .lt1
Old 07-31-2006, 06:11 AM
odd. Works with the aol browser but not firefox. Does the 95 look virgin to you?
Old 07-31-2006, 06:22 AM
titter's Avatar
comparing the 2 in cats tuner it looked virgin ... i didnt go through the constants table, but the line pressure was def. stock! clear your firefox cache, his files just recently changed. that page might be cached in firefox.
or google for a program called ccleaner, it will clean up all the temp garbage on your computer. i use this about once a week.
Old 07-31-2006, 06:32 AM
Thanks. I'm using ccleaner now
Old 07-31-2006, 06:45 AM
titter's Avatar
works great lol!
Old 07-31-2006, 07:06 AM
I still cant get any of them to unzip. Something is wrong. Can you send it to me? Also could you send me the 94 vette file if it will unzip?
Old 07-31-2006, 07:42 AM
slowmofo's Avatar
I have one, but its at home. I know for a fact its stock from my 94. I can send it when I get home if you want
Old 07-31-2006, 08:11 AM
Cool. Thanks.
Old 07-31-2006, 08:36 AM
titter's Avatar
you dont have to unzip them ... just take off the .zip file extension. he had to name them like that for his host probably, some hosts dont allow transfer of unknown file types.
Old 07-31-2006, 09:18 AM
Oh, ok. So I just add bin to the end?
Old 07-31-2006, 10:23 AM
How do I make them .bins? Ive tried everything.
Please note: The due to some changes in the server, files with a .LT1 extension can't be directly downloaded. I have added a .ZIP extension to the files. But, these ARE NOT zip files! I only added the extension to allow you to download them. After downloading the file simply remove the .ZIP extension and you'll have a good .LT1 file.
Old 07-31-2006, 02:18 PM
slowmofo's Avatar
Sent you that tune... its from asmoser@hotmail.com
Old 07-31-2006, 02:35 PM
Thanks. I'm at work now so I dont have access to it but Ill check it when I get home To bad the POS Camaro wouldnt idle. Nothing has gone right since I went Chevy. I shouldve stayed Ford and stateside UGH!!!!
Old 07-31-2006, 04:08 PM
titter's Avatar
.lt1 is the same extension as .bin ... what program are you use tuner cats? if so just goto all files, and open the .lt1 and save it as a .bin
Old 07-31-2006, 04:34 PM
infinitebird's Avatar
I have one also if you need one, which gears? (The shift points, etc. are different for the 2.73 vs 3.23 cars).
Old 07-31-2006, 04:39 PM
Actually good point. I didnt think about that. It has 4.10 gears still. Never swapped back stock.
Quick Reply: Stock 1994 Z28 A4 bin.
