maybe you guys can help
Its been awhile since ive been on here... My question is about the suspension on a 95 vette... We had done all for shocks and she has the selective ride control my problem is that the service ride control light in on now and wont go off for $hit.. Does anyone have a suggestion for me??? Let me know and thanks
13,14,21,31,32,33 is the codes that were pulled granted the light wasnt on before the install of the shocks. Second the guy that installed them didnt remove the battery cable when removing and installing the fronts but did do so for the rear's hope this helps.... thanks again
ok, quick question... how and what did you use to pull these codes... and im assuming its an OBD 1 car by the code numbers. if you used the tech 1 to pull these was this under engine or chassis??? cuz those codes are engine codes... let me know and i will try to be better assistance.
