Fuel Pump..........
Originally Posted by TwoFast4Lv
Depend on how many bears you drink while doing it
Originally Posted by Camaro94SS
Anyone know any good guides for the hole on top of tank? I've heard of this but never seen any guides or anything on it......anyone?
Just be very careful when you're cutting the sheetmetal -- you CANNOT cut deep, otherwise you're going to be cutting into fuel lines. Naturally, that paired with sparks = bad news.
You can usually pick up sheets of metal (sheetmetal!) and some shallow sheetmetal screws at your local hardware store. (HomeDepot carries all this in their nuts&bolts section.) I'd probably use RTV to seal it.
-I personally removed the gas tank so that I could clean it out, but next time I'll be using the 'trap door' method as well.
One question...my gas tank guage is totally fucked up and goes crazy when i get to like 1/4th tank....if i replaec fuel pump will this be fixed? or are there other floats inside the gas tank??
IIRC, there are three wires going into the tank -- gray, black, and purple. Black is ground, purple is the fuel level sensor signal (to dash), and the grey wire I believe powers both the pump and the level sensor.
Prehaps the wiring is buggy, or the level sensor is shot/broken. If you have a digital voltmeter, you'll have to play with it when you get to that stage.
*[Edit] I may have those wires confused. It has been a while...
Originally Posted by emj2006
Cut a hole through your car? Where exactly. Won't the smell get inside or something?
Alex94TAGT Thanks for the link with the images. I have replaced mine twice the old fashioned way. I was going to remove it again this weekend to add a additional fuel source for the direct port nitrous and now I will make the hole.
